It is currently Fri Aug 01, 2025 8:44 pm
PostPosted: Sat Oct 25, 2008 10:42 pm
Anyone have a good setup for safety-planer? I like it alot, but it really spits out the wood. I have a semi vacume system set up, but it still spits out, it may need a covering devise or something.
Anyone have a great design they want to share??? [:Y:]
I am looking a a coffee can that surronds it and leaves some space, with some type of flexible skirt, rubber of a sort, with vacume attachment, mounted to the side.
PostPosted: Sat Oct 25, 2008 10:49 pm
The problem with that is that you really need to see what it is doing. Everything I have tried failed miserably.
PostPosted: Sun Oct 26, 2008 12:24 am
Hmmm, and what have you tried? :mrgreen:
The problem is that as soon as it hits center, it starts throwing out chips. So it needs to be fully encircled.
For minimal thicknessing, I just add pieces of thin, slick cardstock and keep the press in place.
PostPosted: Mon Oct 27, 2008 2:07 pm
I hang a shower curtain around the drill press and then step in and do the work. The chips hit the curtain and fall to the floor. Much easier to clean up.
All I need now is soap on a rope.
PostPosted: Mon Oct 27, 2008 2:26 pm
First name: Kirby
idunno
http://www.bearmeadow.com/build/methods/wood/Thickness/html/Milling-to-thickness.html
"It's a Tone Faerie thing"
PostPosted: Mon Oct 27, 2008 4:35 pm
Barry, pretty cool! But doesn't the vinyl do a static electricity thing with the dust? If only it would ALL stick.....
Dan
http://www.acme-archtops.com
PostPosted: Mon Oct 27, 2008 5:11 pm
I think the brushthing might work, but it would only cover 180 degrees, or less. Where do you get the round hanger for a shower curtain?
PostPosted: Tue Oct 28, 2008 12:30 pm
Ok, I think I designed a better working, fairly simple setup, as long as the wood is thin, and not too wide...Ill try to post some pics when I get it done.. :geek:
Users browsing this forum: Bing [Bot] and 34 guests
